starter and cable
starter and cable
I agree that it is the starter. I will add that you should replace the + battery cable. When the starter is failing it draws a lot of amps and will cause the cable to overheat. Often after this happens a lot the cable will increase in Ohms. I replaced a starter last year and within a month or 2 the cable went.
Z28/ZR1
Oct 23, 2015 01:04 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
