Which is better a 383 or 327??
Old Sep 22, 2000 | 12:22 AM
Metallica383's Avatar
I want to know how high of a piston compression i can run on normal gas and How much power I can easily get out of both the 327 and the 383 with not a real wild cam and which motor will crank the most RPMS?
Old Sep 22, 2000 | 12:52 AM
Tas's Avatar
Tas
-power from reving high
-means crazy cam
--means low mpg
--harder to pass smog
383
-power from torque
-more expensice parts to make spin high
-better on mpg(because of torque)
etc.
I'm tired
more later
Old Sep 22, 2000 | 12:03 PM
RSS's Avatar
RSS
I would much rather have a 383 under my hood.
Old Sep 22, 2000 | 11:55 PM
GOLD85's Avatar
i'm planig on doing a 383 build up. 383s 4 ever
when the green flag drops the bull$hit stops
350,performer RPM intake ,650dp, 700r4, headers, 3inch exhast
Old Sep 23, 2000 | 10:54 AM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
I agree with everyone else, a 383 would be a better choice, and if you worried about the power -> mpg type thing. Depending on what type of fuel injection method you use. I know of a guy pulling 19 mpg in city with his 383. I have no idea what parts, etc that he's useing but i know its fast and get dang good gas mileage. Then again its carbed, little easier to tune. At least from what i remember (been a while since i've messed with a carb)
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-Rebuilt 700R4 Tranny
With the goodies to go
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
Old Sep 23, 2000 | 07:36 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
i'd also say the 383. only time it is not a better choice is if you have a small car. same hp can be made with both, but 327 will have to be twisted up alot higher to make it and have considerably less torque.
LT1Formula
Oct 8, 2015 08:34 PM
JSDaddy189
Sep 26, 2015 03:50 PM
