LEXAN T-TOPS ????
Old Sep 22, 2000 | 02:04 PM
PAformula's Avatar
LEXAN T-TOPS ????
My driver's side t-top is bubbled up. Has this happened to anyone else? It make a loud wind noise at highway speeds.
Is it possible to get new t-tops cheap? If so, where? I've been looking at used ones that are worse condition than what I have.
thanks
BLACK 1989 FIREBIRD FORMULA 350
K&N, ACCEL CAP & ROTOR
Old Sep 22, 2000 | 04:39 PM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
I haven't had any problems with mine or any of the ones that I've worked on bubbling, its not just window tint is it? The only place that I can think of to get a good set of T-Tops is at the junkyard, but I did see a set on Ebay a little while ago. The junkyards are gonna be your best bet though
-Mike
Old Sep 22, 2000 | 06:43 PM
Vader's Avatar
Jason,
Yards around here were askign $175.00 per pair of glass tops. They were readily available, depending upon the type of retainer mechanism. The Lexan tops are prone to thermal distortion and optical hazing over time. They are considerably lighter than the glass tops, however.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Sep 22, 2000 | 10:18 PM
drain89's Avatar
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
I found this site the other day. I haven't contacted them. http://www.tgautomotive.com/products.html
Good Luck.
Old Sep 24, 2000 | 02:36 AM
B L A D E's Avatar
A pull it yard in Morrisville PA (near philly) has T Tops for $11...one problem...you gotta get em before someone else... usually not that hard though....
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
meeklay812
Oct 1, 2015 03:46 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
