Cylinder Heads
The 305TPI head has a 58cc chamber and intake valve size is 1.84".
The 350TPI head (iron) has a 64cc chamber and intake valve size is 1.94".
The exhaust valve size is the same on both at 1.50".
85 calif. iroc
383/A4
9" rear
85 calif. iroc
383/A4
9" rear
It's not hard to do... It just takes a long time. Using a dremel tool, drill, and all sorts of bits. most machine shops are not willing to do it because its to long, and if they do it might cost you. The best is to do it yourself. Ask Vader about it, he might know. in the meantime, I'll try to find you some references. BRB
MikeInAz has great tech articles on porting and surely polishing
http://members.aol.com/mmmm999/3rd-degree/index.html
Look at his plenum porting article, its about the same has head porting... You'll get the idea
http://www.tribal-treasures.com/cars...-port/port.htm
Chuck84TA
Jul 15, 2016 09:05 PM
NinjaNife
Aug 23, 2015 11:49 AM
