How much will the Edel base and AS&M runners knock off my time?
Mkos,
Before you rush out to get an Edelbrock base, you might want to check the archives for some of the recent threads on these intakes. A few members have experienced problems with them, and you might benefit from their experiences.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Later,
Vader
"Make Me Bad"
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Too late
before i bolt it down i am going to connect all the injectors and lines and put them in the bores then turn key on. if its not leaking then i will bolt the manifold down to the block.
before i bolt it down i am going to connect all the injectors and lines and put them in the bores then turn key on. if its not leaking then i will bolt the manifold down to the block. Thread
