How do i do this
Old Jun 16, 2003 | 06:10 PM
tbfirebird's Avatar
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
How do i do this
okay ive got a 1989 Firebird formula with the 305 tbi engine and was wondering how to do a brake stand do i just hold the brakes and mash the pedal sown to the floor and pray that the trans or rear end dosent go or do i have to take the rear drum brakes off.
Old Jun 16, 2003 | 06:17 PM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
assuming you have an auto trans, you just apply the brakes and give it gas at the same time. Only use enough brake to keep the car from moving while the wheel(s) spin. DO NOT take the drums off!! This will cause you to have no brakes at all because the shoes will have nothing to push against, even your front brakes won't work! That sounds like a good plot for Jackass
Old Jun 16, 2003 | 06:47 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
By "brake stand", do you mean "burn out"? As in, keep the car from moving while you let the smoke out of the rear tires?
It is possible to balance how hard you press the brake pedal and accelerator, and do that. It's easiest if the rear tires are wet, though. It is also a little hard on the rear brakes, because the brake shoes are in contact during this exercise.
The best way to do this is with a line lock, a solenoid-activated valve that closes the pressure off to the front wheels (after you press on the brake pedal), which keeps the front wheels locked when you let go of the brake pedal - releasing the rear brakes. The solenoid is operated via a switch in the driver's compartment.
The worst place to do this is in public, on a public road, in a parking lot, or any place other than a drag strip where this activity is performed safely and legally (and with a purpose).
Old Jun 16, 2003 | 07:11 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Yes. Otherwise this can happen.
https://www.thirdgen.org/techbb2/sho...hreadid=182780
Old Jun 16, 2003 | 09:13 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I was going to comment about showing off around friends, then clicked on the link.
Hope others click on it as well.
Two weeks removed from the tragedy, hope you're doing okay.
