Drum to Disc rear end swap Q's
Old Sep 25, 2000 | 12:27 PM
84IROC's Avatar
I have an '84 Z28 with J50 rear drum brakes and recently I purchased a '92 Z28 J65 rear disc/posi/3:42. Has anybody performed this particular swap and if so what problems can I expect? I read on another post that someone had a problem with hooking up the E-brake. I have all the cables/brackets from the calipers to the E-brake splitter from the '92 as well as the brake line that runs from the proportioning valve to the rear axle(because it has a different bend in it to the valve). I also ordered a new proportioning valve for the '92 because I was having trouble locating one from the wrecking yard. I was told two different stories about whether or not I had to go with a rear disc specific prop. valve, any body have any info? Thanks alot......
"84Z28/'91 305TPI comp cam flowmaster TB coolant bypass/shutoff valve to heater core MAT relocated Ram-Air(home-made) gutted air-box IROC ground effects/wheels GY245/50's 700R4 superior shift kit/ corvette servo(excellent shift kit BTW) Rebuilt engine and transplanted it myself. Love this engine!
LOW performance people should drive low performance vehicles!
Old Sep 25, 2000 | 12:41 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Well I'm pretty sure you can keep your J50 master cylinder. That was my biggest headache on the car.. when I went from '86 drums to '84 discs, I got a bad rebuilt m/c, and spent a week on the brakes.
82-88 used different m/c's for J50 and J65 brakes.
89-92 used the J50 master cylinder for both braking systems.
You can verify this thru places like carparts.com or wrenchhead.com .. look up both cars's master cylinders.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Old Sep 25, 2000 | 04:08 PM
brent walden's Avatar
I did that swap. I have a 91 firebird that came with a drum brake open differential rear end and I swapped in a posi disc rear end out of a 91 Z28 and I didn't run into any problems what so ever. It was just a simple swap.
Old Sep 25, 2000 | 04:54 PM
84IROC's Avatar
Brent, did you change the proportioning valve?
Old Sep 26, 2000 | 06:50 AM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
The p-vavle change at some point, There is a first designe and a 2nd, you may want to go back to as far as 89 (same brakes) and get the first 1, that is what I had to do.
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Moroso Blue max wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
AkDrifted
Aug 17, 2015 07:45 PM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
