TPI Camshafts
Old Sep 26, 2000 | 04:50 PM
CamaroX84's Avatar
TPI Camshafts
Will the regualar small-block Chevy cams that you see in Summit and Jeg's work with the L98 TPI motor, or do I have to get a computer-compatible one? I am very confused on what cam to get. I have a 350 TPI motor, and I am looking for the RPM range between 2000 and 6000. What would you guys recommend? Thanks.
Old Sep 26, 2000 | 05:06 PM
Dan87IROC-Z's Avatar
I think that since the Summit cams are hydraluic, that they should work just fine so long as you use the stock GM lifters and all that.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Components, K&N Filters, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.3 @ 97mph
(corrected for elevation)
Old Sep 26, 2000 | 05:08 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
I would go with a cam from one of the Tuners. Accel/LPE, TPIs, SLP, ect. They put alot of development into TPI FI cams. The opening and closing events need to be tuned for the Type of induction system you plan on using. Long runner TPI, SuperRam, Miniram, Most all have had a cam tuned for them why not take advantage of it.
Mike
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Old Sep 27, 2000 | 12:51 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Check the tech article here on camshafts, it goes into detail and gives lots of examples of good cams to use for TPI.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Caspar
Jun 19, 2016 11:19 PM
gta90
Sep 15, 2015 04:00 PM
blackroc68
Sep 1, 2015 08:01 PM
midge54
Aug 29, 2015 09:51 PM
Sanjay
Aug 12, 2015 03:41 PM
