fuel injectors
Old Jun 21, 2003 | 05:02 AM
jodylee8310@aol's Avatar
fuel injectors
anyone know the readings for the fuel injectors for 5.7ltr 350 and how to properly test them
Old Jun 21, 2003 | 05:51 AM
ede's Avatar
ede
what reading you after? resistance, pulse width, flow
Old Jun 21, 2003 | 08:59 PM
readings
im looking for the resistance across the connectors to the fuel injectors i pulled wires off and tested why car was running and it was jumping around quiet a bit
Old Jun 22, 2003 | 08:54 AM
Vader's Avatar
The resistance across the injector connector should be between 12.7 and 16.8 ohms. The resistance of the harness is going to change depending upon whether the rest of the injectors are connected or disconnected, and how the ohmmeter is polarized, since you will be reading the resistance of the output transistor and its biasing circuit in the ECM.
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
