Help Again Plz
Old Jun 24, 2003 | 04:43 PM
trickedout02's Avatar
Engine: 302 5.0
Help Again Plz
I was changing out my spark plugs from the regular ac delcos to the ac delco rapid fires, when I got to spark plug #3 and noticed that it start spining when I tried ratcheting it out.... but it would go no where, it was loose too... My friend told me if I noticed any hesitation in it when ever I drove it, and I did notice a hesitation when ever I pull it out on the high way... Which was only twice so far. I barely ever drive cause I am waiting for my hypertech chip and hypertech 180 thermo.... Plus no tags no insurance. is disconnecting the drive shaft difficult cause I need to pull the tranny to replace the speedo sensor and the rear main seal.
The most important thing so far though is the spark plug, my friend came up with the idea of getting new heads.... I don't really want to do that but it might be best. Is there anyway I might be able to get it out and just retap the bore???
91 3.1l V6 Camaro
DJ:lala:
Old Jun 24, 2003 | 04:48 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
A Heli Coil usually works.....And much cheaper the new heads.
Old Jun 24, 2003 | 04:53 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Sounds like the threads in the head are stripped. You could try helicoiling the head with the bad spark plug hole. Disconnecting the driveshaft shouldnt eb to difficult. Havnt had to unbolt the u-joints yet on mine but that shouldnt be too difficult. Whatever you do, just dont take the yoke out of the rear of the trans, itll be a mini niagra falls of ATF if you do.
inferno15
Aug 29, 2015 01:48 AM
BitchinCamaro
Nov 28, 2001 01:51 PM
Amrish
Nov 9, 2001 11:33 AM
Amrish
Jul 16, 2001 02:16 PM
