Help rusted on!
Old Sep 29, 2000 | 10:56 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
Help rusted on!
The rotor is rusted on the distributor, got it off a pain in the A** how do I stop it from happening again. Buy the way when I pushed the new Accel rotor on it split up the back side whats up with that?
87 Z28 305 TPI, Auto, Gutted air boxes, K & N fillters, Dyno Max 3" cat back.
Old Sep 29, 2000 | 11:10 PM
Vader's Avatar
New,
You'll have to get the rust off the distributor shaft. The extra diameter of the shaft fro the rust buildup is probably what caused the new rotor to split.
Try a low abrasive method to remove the rust, like a ScotchBrite pad. Cover the pickup coil and reluctor as best you can before starting. a plastic bag and masking tape should keep most ot the rust out of the distributor. Scour away all of the rust you can, then try another rotor. Once the distributor shaft is clean you shouldn't have any more problems with rotor fitment.
When you install the next new rotor, rub a small amount of dielectric silicone grease on the shaft to stop it from rusting any further.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Fireslash
Apr 11, 2016 06:43 PM
FueledSoul
Sep 30, 2015 09:18 PM
tcflint
Sep 27, 2015 05:58 PM
