what to look for in a good pair of heads?
Old Jun 24, 2003 | 10:05 PM
Firl's Avatar
I have a 1986 350 block that came out of a suburban in my camaro now. I want to upgrade the heads, but do not know what to look for in what I want, I was told by a mechanic that I probabbly don't want to put something extreemly good on top of the block since the block has not ben rebuilt, but something moderate could work well.
Is there any sites that anyone knows about that explain all this that I can read up on?
Old Jun 24, 2003 | 10:28 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
It's prefrence mostly. The heads wont kill an old engine. I personally would try local machine shops to see if anyone is parting with thier old performance heads at a reasonable price. That's where I get my heads, except these Dart POS's took a dent there. Just look for the best heads in your budget, you can always build an engine around the heads since they are an investment.
As far as websites. Most of them are biased.
Also 416's are a nice upgrade and thier dirt cheap but Id call and see what you can find.
Old Jun 24, 2003 | 10:31 PM
Firl's Avatar
With its preference Should I just take off my 350 head I have currently and modify those or just look for a nice pair around here?
Old Jun 25, 2003 | 12:34 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
depends on the heads.. remove a valve cover and write down the casting number then post it on here im sure someone will be able to tell you if they're worth the time or if they'd make better wheel chucks them proformance heads..
Old Jun 25, 2003 | 12:36 AM
Firl's Avatar
but ... but ... I JUST got the gasket RIGHT where i wanted it! lol I will look for that soon, thank you
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
CRFred
Feb 7, 2016 11:39 PM
NinjaNife
Aug 23, 2015 11:49 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
