Need quick help on 083 casting heads!
Old Jun 26, 2003 | 02:10 PM
prOject-IrOc's Avatar
Car: 1990 Iroc-Z
i have a friend who has some 083 heads, and he has put about $600 into them. i can probably get them for $300. they have porting of the intake and exhaust ports (There is scribing paint on the intake ports for additional porting if desired), cut for 2.02 intake valves and 1.60 exhaust valves, new valve guides, machined for screw in rocker arm studs and larger size valve springs, resurfacing and they have been coated with an industrial strength high heat coating.
Sound like a good deal?
Old Jun 26, 2003 | 02:26 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
A good set of valves is about $150-175, springs and all their hardware are $150 or so, studs are about $40.
Add it up, and see if it's a better deal than a brand-new set of better-quality castings in the first place, with all that stuff already there.
I'd say it's real close to the dividing line.
Old Jun 26, 2003 | 02:30 PM
Car: 1990 Iroc-Z
i think im going to grab them. i can't afford to buy new heads, but i can get these and buy each piece one at a time.
they look really clean, and he has reciept for $572 bucks of porting work.
thanks alot for the quick reply....anyone else?
Old Jun 26, 2003 | 03:23 PM
Car: 1990 Iroc-Z
he says they flow 250 on the intake side and in the high 180's on
the exhaust side. whats stock flow?
Old Jun 27, 2003 | 02:08 AM
badone07's Avatar
You should be able to find it here in this thread. Just read through the different parts posted by rhuarc31 ...
https://www.thirdgen.org/techbb2/sho...hreadid=183264
Chuck84TA
Jul 15, 2016 09:05 PM
camaro71633
Sep 1, 2015 10:24 AM
NinjaNife
Aug 23, 2015 11:49 AM
lakeffect2
Aug 23, 2015 08:44 AM
