TIming Question
Old Sep 30, 2000 | 08:16 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
TIming Question
Hey quick question, If I have my timing mark on the balancer at 0 and the dist. pointing at the #1 cyl. on the Dist. Cap is that TDC on the intake.
Brian Felts
Old Sep 30, 2000 | 08:30 PM
Vader's Avatar
Brian,
If the distributor has never been disturbed, that should be TCD on the compression stroke - both valves closed on the #1 cylinder. If the distributor is pointed directly away from the #1 cylinder, that would be TDC on the exhaust/intake strokes.
BTW - I presume we're talking about a SBC V-8.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Oct 1, 2000 | 03:23 PM
Yes we are talking about my 89 305 TBI Camaro. I will pull the valve covers and check the valves I just want TDC before I pull the motor.
Thanks So Much
Brian
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
