HELP....What did I do?
Old Jun 29, 2003 | 05:43 PM
LPE383's Avatar
Car: 84 Z28
Engine: 350 L98 from 89 vette
Transmission: World Class T5
Axle/Gears: 3.70 Precision Gears
Yesterday, while driving home I ran a stang on the highway that came along side of me. Later when I got off the highway I heard a knocking sound. Currently I don't hear it at idle but as the rpms increase it starts knocking faster and sounds like it's coming from the drivers side near the head. Any ideas on what I did to the motor??? If I rev it I don't really hear it but if I hold the rpms steady say at 2,000 it's pretty loud and goes up with the rpm!!
sorry, didn't know what other topic/thread to put this under!!
Old Jun 30, 2003 | 05:17 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: HELP....What did I do?
Tech/General Engine.
But, anyway, if this is a true "knock", and it sorta sounds like it is, you wiped out a bearing or two. Cheap or used-up oil, and/or a weak oil pump, will do that to you.
Old Jul 1, 2003 | 08:23 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
I agree. A toasted bearing or wrist pin. You can have an oil analysis done if you want to know for sure.
Old Jul 2, 2003 | 12:57 AM
Guest
Guest
Posts: n/a
Hate to say it, but I agree as well.
Transferring to Tech/General to see if you hear more bad news...
Old Jul 2, 2003 | 01:11 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Disconnect one spark plug wire at a time while reving the motor to make the noise. If it then goes away when one plug wire is disconnected it is a bottom end problem ( rod bearing, wrist pin, cracked piston) if it is still there it could be valve train, (rocker arm , broken valve spring, collapsed lifter, wiped cam lobe.)
Old Jul 4, 2003 | 04:58 PM
LPE383's Avatar
Car: 84 Z28
I will try that F-Bird. Thanks for the info. I'm going to shoot myself I think if I have to pull this engine out!!! I'm currently putting back together my 383 LPE Vette and now this happens!! I'm sick!!!!
Old Jul 10, 2003 | 04:01 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
At best, it could be an exhaust leak.
