Lucas Oil Stabilizer...
Old Jun 29, 2003 | 08:39 PM
BORLAZ06's Avatar
Well I thought I'd add some in since I'm doin my oil change. Added bout 3/4 of the bottle (Oil Stabilizer). Took my car for a little drive earlier and my oil pressure is alot better now. In traffic it stood over 30 and never got any lower and this was at 235* lol. Any one else have good reviews or bad experiances with it. No more worries with the power adder now
Old Jun 30, 2003 | 10:24 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
My impressions of it are that it's basically just a thicker oil. Keep in mind I have no personal experience with it. I just "know" what I've read.
Old Jun 30, 2003 | 07:41 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
i've used they're oil aaditive with no ill complaints. slighty higher oil pressure and quiets noisy lifters. good product. it leave a sticky, greasy film on parts and on your skin.
Old Jul 6, 2003 | 12:25 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
I just tried some today. It is some thick stuff. I havent really noticed much difference. I put some of there fuel treatment in to for no particular reason. Maybe it will keep my carb nice and clean.
Old Jul 6, 2003 | 08:21 AM
Guest
Guest
Posts: n/a
i was going to add some to my car but i was told not to till my motor has over 3,000 miles on it so i'm going to have to wait 1,000 more miles befor i can try it
PS does anyone know if thats true?
Old Jul 6, 2003 | 09:03 AM
92bird305tbi's Avatar
Car: 92 Firebird
Engine: 305 TBI
I use it in my oil in my minivan. Its the only way i can get the oil pressure above 15 lbs. Don't know about long term effects on an engine but the right now effects are great to me.
Old Jul 6, 2003 | 12:50 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
i work in a bus garage where we fix buses up to go from ohio to florida non-stop, and we ALWAYS add the lucas oil treatment. My boss loves it, he adds it to all of his cars (all 1000000000000 billion of them) and the lucas gas treatment works well too. I mixxed some in our toe-motor and it all of sudden is blowing out white smoke for about an hour so it cleaned it out good.
i'll use all lucas products on my cars, including the oil/transmission and gas.
Good results none the less with the buses n vehicles and machines.
Old Jul 6, 2003 | 08:41 PM
Ozzy88GTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
I have seen the display at an Advance Auto Parts and noticed that there were quite a bit of air bubbles in the oil. Now, aren't air bubbles bad for hydraulic lifters since the air tends to compress and the lifter might collapse some? Just a thought.
Old Jul 7, 2003 | 01:39 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I should say it is a thick oil! At 100 degrees C, the kinematic viscosity is 110 cSt. That compares to a certain synthetic 20W50 with which I am familiar with a viscostiy of 18.3 cSt @ 100 degrees C.
Get a reputable oil manufacturer that will tell you in writing that an additive will make their product work better and not void any expressed or implied warranty of their oil, and I'll buy you lunch.
Old Jul 8, 2003 | 09:29 AM
Svelte_SS's Avatar
Car: 1987 Monte Carlo SS
Engine: 5.7L TPI
Transmission: 4 spd auto
That's a hell of a sig you got there...
Old Jul 8, 2003 | 04:54 PM
Vader's Avatar
...and a good bit of logic above the signature. Try to find even an oil refiner, synthesizer, or blender that will advise you to use an additive and I'll add the dessert to that lunch... I said "refiner, synthesizer, or blender" which means someone who actually knows something about the product, not an oil seller. For example, Exxon/Mobil is a refiner, synthesizer, and blender. Amsoil and Kluber are blenders who purchase base stocks and add components. All of those have a really good handle on what's what in lubrication. Shell is a refiner and blender. Citgo and Marathon are refiners and blenders, as are Pennzoil/Quaker State and Clark Oil. Lucas doesn't make anything except oil additives (and money). For the most part, they don't even "make" any of those additives - they only mix other manufacturers' products.
Write to GM Powertrain and tell them you "Really want to protect your new Corvette or Cadillac and plan on using Lucas oil stabilizer from the very moment you buy it." Ask them how much more warranty you'll get because of that. If they reply at all, you'll probably get a voided warranty certificate notice back in the mail...
Any time a product uses testimonials instead of technical data in their advertising, you should be suspect. Look at the LucasOil.com site, and see if you can find technical data. Lots of testimonial (which is simply another word for "opinion") but no data. Hmmm... Could it be that they'll be in the same trouble that other companies who've used testimonials in their advertising have experienced? Companies that sold crap like ProLong? Slick-50? TMT? Will the F.T.C. be making gobs of penalty money from Lucas, just like it did from all of those? I've gotta wonder.
As for the OTR busses, I'm glad you're having good success with the additive. Take those 40 passengers out of the bus and fill it with 80,000 pounds of taconite and see how long it lasts. Trucks in the iron range do that for millions of miles with REAL loads, and do it on Delvac or Delvac synthetic, not glorified additives. Trucks in teh Rocky Range with three pups do it on real oil. Trucks in the Great Lakes basin regularly do it with 120,000 pounds of crushed rock and don't need additives (and don't wear out prematurely, either). See if any of those engine manufactureres, like Caterpillar, Cummins, Navastar, Detroit, or Benz offer any advice on additives.
STP does the same thing, and has done the same thing for decades. If I had a smoking, worn, P.O.S. engine, I might try either of those as a temporary solution, too.
Come to think of it - no, I wouldn't. I'm at a point in my life that I'd repair it correctly instead of sticking on band-aid "fixes". I get tired or rework and substandard crap.
But that's just my "testimonial"...
BTW - I hold 55 PSI at 1,200 RPM with only Mobil 1 10W30, but that's only at 95°F air temperature and 205°F coolant temperature. I try not to run at 235° if I can avoid it.
Old Jul 8, 2003 | 07:42 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
I have used the product, it does do what it claims egrr.. what people testify about. It does raise the oil pressure and stop some smoking problems. If you want a band aid for the engine then yes it does work temporaraly, its not guide seals/pistion rings in a can. I do use it in my transmissions that I dont think are worth running synthetic in and it does hold up better then gear oil or ATF with no ill effects yet. But then Ive got the original 3.73 12 bolt from my truc with well over 400K on it never been touched, bearings NEVER replaced running Amsoil in the differential since 76.
Old Jul 8, 2003 | 09:10 PM
slayer2000's Avatar
Car: 1990 GTA
Transmission: manual/t56
keep in mind using something to raise low oil pressure is just masking the syptoms. My buddys 94 camaro with a lt1 auto started showing low pressure and the oil light started to come on when warm at idle. After spending a week checking wires, sensors and so forth he finally pulled it and took it to be rebuilt. When we torn it down the number three main was dead and the other s were on their way out(all were down to copper) It didn't make any noise but if he had kept running it instead of fixing the problem he'd probably would have ended up buying a new crank instead of being able to save his old one. something to think about
Old Jul 8, 2003 | 09:18 PM
biff85ta's Avatar
Car: 04 Vette
I was formely employed by a quick change oil place and I can safely say the reason why I am not there now is because I could not sell people the snake oil fixs they expected me to and sleep at night.
Old Jul 8, 2003 | 10:10 PM
Vader's Avatar
Originally posted by SSC
... But then Ive got the original 3.73 12 bolt from my truc with well over 400K on it never been touched, bearings NEVER replaced running Amsoil in the differential since 76.
I'm guessing that you can attribute the long life of your axle to good design and Amsoil, not any additives you may have poured in.
Old Jul 8, 2003 | 10:33 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Yes, its funny because in 400,000+ miles its only been serviced a couple times that I know of.
Old Jul 9, 2003 | 12:28 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Wow!!! And what a "testimonial" it was Vader!!! LOL!!
First thing I thought of when I read this post was "STP".
I always thought it was a poor man's way to extend an oil change when the oil in your car has pretty much "broken down" and you're running high on miles, also helps raise your oil pressure because it's as thick as molasses....
Old Jan 28, 2004 | 05:43 PM
seek007's Avatar
Car: 87+
kind of an old post to awaken but i've used it and it does seem to help (all other additives dont seem to do much, if anything)
it is very thick and can be used as a thickening agent, i suppose it might last thicker longer than the oil it self, but i've never had that problem considering i am always adding more oil
does this stuff help prevent dry starts?
Old Jan 28, 2004 | 07:43 PM
Meatikis's Avatar
Car: '86 Z-28
Engine: 350 bored .030 over
...and a good bit of logic above the signature....
holy crap vader, were'd you go to rocket science school at? it's probably safe to say you are the last word on topics such as these. wish i knew as much as you:hail:
Old Jan 29, 2004 | 01:18 AM
joshwilson3's Avatar
Old Jan 29, 2004 | 05:55 AM
ede's Avatar
ede
run a pint or so of ATF for 500 miles before each oil change if you want to clean the engine. it's cheap and easy.
Old Jan 29, 2004 | 12:54 PM
Old Jan 29, 2004 | 04:29 PM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Transmission: Worn-out 200R4
Axle/Gears: BW 9-bolt, 3.27's
Yeah, what gives with the ATF thing? I've seen it here a lot and would like to know the bottom line on what the ATF actually does, if you don't mind me asking...
Old Jan 29, 2004 | 05:44 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Have a look and then see if you still want to waste your money and pour that crap into your car.
http://www.bobistheoilguy.com/images/lucas/lucas.htm
Old Jan 30, 2004 | 02:00 AM
Old Jan 30, 2004 | 03:28 AM
25THRSS's Avatar
The mobil 1 is doing it's job then. Just give it time. I've been using it since I basically got the car and my engine is literally spotless inside.
Old Jan 30, 2004 | 03:39 AM
Old Jan 30, 2004 | 11:25 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Originally posted by joshwilson3
Are you replying to me?
No
Old Jan 30, 2004 | 12:14 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
As stated above, don't use Lucas, or any other "racing" oil unless your engine does nothing but drive in those conditions.
Lucas has a very specific additive package that is designed to help lubricate at high rpm for extended periods of time.
so lucas might be a good buy for your circle track car that runs at 6000rpm for 4 hours straight.
but for your street car lucas simply wasn't designed for street driving.
save your money and your engine, and avoid oil additives like the plauge. (excluding posi additive for your differential, and the such)
a good fully sythetic oil is about as good of lubrication you can find for you street engine in this day and age.
Old Jan 31, 2004 | 01:47 AM
Old Jan 31, 2004 | 03:54 AM
Confuzed1's Avatar
Car: 83Z28 HO
What do you think about auto-rx? That is something you use to clean out the engine. I've read alot of good stuff about and on the bobistheoilguy.com website. It is even endorsed by Terry Dyson, which I hear is a very knowledable individual.
But that's an engine flush, not an additive per se. It doesn't stay in the engine...
They used to have this stuff called "Motor Flush" I think.....
You added a Qt. to the oil and ran it for 1/2 hour after it warmed up.
Then you changed the oil. The stuff works!! I haven't used it for years since I switched to synthetic oil. IMO that's one of the major advantages of running synthetic oil. Engine stays clean....
Old Jan 31, 2004 | 10:42 PM
Old Jan 31, 2004 | 11:54 PM
Confuzed1's Avatar
Car: 83Z28 HO
Straight from the web site:
Auto-Rx®, (US Patent # 6,544,349), is a specially formulated, all-natural metal cleaner designed to thoroughly clean the internals of your engine.
I guess you could apply the word "additive" since you are adding it to the engine. I guess you could wordsmith other things in the description too. Besides, I was referring to the Motor Flush, not the Auto RX stuff.
I'm not claiming to be some kind of "expert" on what additives work or don't work. I'll leave that to the people that think they do - I just know what's worked for me....
Old Feb 1, 2004 | 12:59 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
sure it'll quiet some noises and even may solve a smoking problem.. true.. its also true that you can quiet a rod knock with some gear lube in the oil.. i wouldn't refer to either of them as a "solution"..........never made sense to me, it simply accomplishes the same thing as switching to a thicker oil for the price of the oil + the addative.. what will they think of next?
Old Jul 28, 2008 | 04:12 AM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
Re: Lucas Oil Stabilizer...
the only problem i have with his experiments is that he has 2 variables and no control, wouldnt it make more sense to have 1 regular oil non synth, 1 fully synth, and then 1 non synth with lucas and 1 fully synth with lucas in it? because i mean all that is proving to me is that lucas doesnt work with synthetic oil. also he doesnt state how much additive he added, when u add additive to your engine or rear end its a certain proportion, by that i mean theres a pint of additive to 3 quarts oil. ive added lucas to my oil, yet my oil doesnt look like starbucks coffee, is it perhaps that im a special case? or that maybe that milkshake effect just doesnt happen to anyones car. has anyone here had the same results as bob?
and whos to say whos pocket is this guy in? all im saying is that obviously lucas has been making products that people find effective. but i do know that website is useful ive read it before, he has this section on oil filters and how fram is complete junk, but thats besides the point, and this is just my two cents, oh and lucas makes a zinc additive for my flat tappet cam engine, so i do trust them
Old Jul 28, 2008 | 04:37 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
dead old and tired post but it does bring up a couple answers to some questions that are bound to come back around once more.
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
Numbah-1
Oct 2, 2015 08:27 AM
meeklay812
Oct 1, 2015 03:46 PM
