Raising the tpi powerband
Old Jul 1, 2003 | 01:30 AM
123jon321's Avatar
Car: '86 iroc
Engine: lb9 305
I'm planning a 350 swap into my 86 iroc/305 and would like to know the best way to raise the powerband of the tpi. I've read that the slp siamesed runners help top end, would these be a better choice than the ASM long tube runners for my application? It's going to have the vortec baseplate as I'm using vortec heads. With porting of everything involved can I expect any kind of noticeable difference in top end performance?
Old Jul 1, 2003 | 03:51 PM
prOject-IrOc's Avatar
Car: 1990 Iroc-Z
slp runners...get them siameased, ported plenum (knock out walls), and a 58mm tb. definate power increase, and more rpms.
lt4 hotcam would be next on the list.
might want to think about bigger injectors with that setup though.
Old Jul 1, 2003 | 06:25 PM
123jon321's Avatar
Car: '86 iroc
Engine: lb9 305
Oh yeah, I'm going to get 24 lb. injectors. I want to use a pretty aggresive cam thats why I'm seeing how I can raise the powerband. I was thinking of something around the comp cams xe 284H cam. Am I wrong in thinking that a LT4 hotcam is relatively unusable with the tpi? The specs on that thing just sound mean. Anyway, Thanks for the info.
Old Jul 1, 2003 | 09:20 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
"mustangs are like tampons, made for pus****."
Gotta love ignorance....
Old Jul 2, 2003 | 02:41 PM
felo72's Avatar
Honestly, not to be rude, but I'd check into a 350. To raise the powerband enough for a bigger cam, head work is a must. And those stock heads on a 305 aren't the greatest. I had a 383 stroker tpi with stock heads. I changed the runners, and the throttle body and actually lost time in the quarter mile. I sold the car before I invested in a good set of heads. But if I would have gotten them, I'd be in the 12's or better.
If you really want something to raise your ET's, nitrous always helps.
Old Jul 2, 2003 | 03:49 PM
Car: 1990 Iroc-Z
he DID say he was going to put a 350 in w/vortec heads...
"It's going to have the vortec baseplate as I'm using vortec heads."
....yeah, ignorance is buying a ford...
Old Jul 3, 2003 | 07:23 AM
felo72's Avatar
Sorry, I missed the first line. I guess old age does that to you.
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
someone972
Aug 30, 2015 12:52 AM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
Sanjay
Aug 12, 2015 03:41 PM
