TPI fuel pump/pressure question
Old Jul 5, 2003 | 08:08 PM
lane's Avatar
I have problems with my car starting. It takes a few trys till it starts. I heard there's suppposed to be a check valve in the fuel system to keep pressure up. I have a feeling this is the problem. Is the check valve part of the fuel pump or is it a separate part. I'd hate to have to drop the tank if I don't have to, esspecially since I just changed the pump a little over a year ago.
Old Jul 5, 2003 | 08:51 PM
Morley's Avatar
The check valve is a part of the pump, sorry. If you have a pressure guage you can pinpoint if it really is the heckvalve or other component in the tank.
Old Jul 6, 2003 | 12:28 AM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
It could be the pump itself, it could be leaking injectors, it could be a bad regulator.
Get a fuel pressure gauge and check the bleed down.
Caspar
Jun 19, 2016 11:19 PM
beachrodder
Aug 25, 2015 08:05 AM
R3500
Aug 17, 2015 12:16 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
