Is this possible?
Old Jul 9, 2003 | 09:15 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
Is this possible?
Ok im looking for a hydraulic roller camshaft with ~.460 lift both ways. All I can find with these lift specs is the lt4 cam. It only has 203/210 separation tho. Id like something around 225/230ish.
That is a fuel injection camshaft...i have carb so I can get away with alittle more cam.
Is it possible to run a hydraulic non roller cam in a roller block? I ask because within the next year I will be pulling this cam (more than likely) and going for something bigger. Since I will be adding heads.
hydraulic cams are cheaper and i could find the cam Im looking for. Im sure roller would add alittle hp tho.
Old Jul 9, 2003 | 11:25 AM
ede's Avatar
ede
you can run a flat cam in a roller block with no problems, just change push rods. look at lunati bracket master series cams, i tihnk they have a .460 lift cam.
Old Jul 9, 2003 | 10:20 PM
Transmission: 4l60e
Ok I need pushrods, the lifters, and the cam correct. I just need a set of pushrods for a non-roller motor right. How about the timing chain. I should go ahead and get a non-roller cam timing chain to correct? Is that all I would need to switch? I can get rid of the spider valley thing and the retainers it holds down right?
Old Jul 10, 2003 | 12:27 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Correct.
Right.
Correct. The cam sprocket is totally different on a flat tappet than it is on a factory roller cam.
Yup.
Right.
Old Jul 10, 2003 | 06:04 AM
Transmission: 4l60e
Would rather buy the comp cam high energy 268 with a .454/.454 with 218/218* ---hydraulic
or a lt4 roller cam that has ~.465/.480 WITH 1.6 rockers. And has a duration of 203/210.
Which would yield better power?
