How much oil pressure will i have using the stock yellow spring?
Old Oct 9, 2000 | 06:54 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
I bought the standard volume pump for a 79Z28 w/350 it comes with a yellow spring. The one I had before i think, came with a white spring. I had oil pressure of 55-60 psi with it. BTW This going in the 406 IM building.
I was thinking if the yellow spring isnt enough i could swap out the springs. How do you get that little pin out to pull the spring out of the pump? IM looking for about 60psi max.
Mike
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Old Oct 9, 2000 | 07:21 PM
ede's Avatar
ede
i use the melling m55 standard preasure pump and get around 50 to 60 psi oil preasure. lot of people replace the spring with the mr gasket HP spring. i weld a brace on the pick up tube and bolt it to the pump.
-=ICON MOTORSPORTS=-
Old Oct 9, 2000 | 07:27 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Hey ede..the one i bought is from sealedpower/federal mogule. The other one i have is the melling pump but its the high volume one.
Its for a Z28 you would think it would have at least 55psi. The guy behind the counter didnt know what the psi would be.
EDIT: I was just looking at the part number on the pump and it says DM 55 isnt that the part number for the standard volume melling pump?
[This message has been edited by MikeH (edited October 09, 2000).]
customblackbird
Aug 15, 2021 10:16 PM
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 21, 2015 09:32 AM
ChevyZ71
Aug 13, 2015 07:30 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
