Rod Bearing Replacement....
Old Jul 12, 2003 | 07:39 PM
z28inmydreams's Avatar
Okay... here's the situation. I'm about to buy an 85 Camaro IROC-Z28. It's got a 305 and it's a five speed. The reason I'm getting this car is because it is so cheap (besides the fact that I am obsessed with third gen camaros). The guy says that the rod bearings are bad on it and that's why he's dumping it. I heard that it would be expensive as hell to take it to a shop and get this done, and I have alot of time to kill this summer, and some money to blow, so I want to do this myself. I have some friends that know about working on engines that can help me out but I was hoping that some of you guys can help me out here. Any tips, tricks, advice, or whatever you have to offer is welcome. Thanks in advance.
Old Jul 12, 2003 | 08:35 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
well since u gotta pull the 305 out anyway why not find a decent 350 n put it in?
Old Jul 12, 2003 | 09:43 PM
RJR99SS's Avatar
well first be sure it's a rod bearing. I just bought a nice 84 buick for a daily driver for real cheap because the owner said it needed engine work. I asked him about it and he thought the lifters were bad because the engine made a *tick* noise consistant with rpm.
So i took it off his hands, thinking at worst i'd just throw a olds 350 in to replace the 307. I drove it around and it seemed to have plenty of power, no stumbles or anything you'd think it would have with a sticky lifter. about 10 minutes looking under the hood i noticed that one of the air lines was rusted out and cracked. I jury rigged a new line out of copper tubing and that fixed the problem, without spending a dime i might add.
So it goes to show you, just because they think it needs engine work dosnt mean it does. You might get lucky....
Old Jul 13, 2003 | 01:50 PM
I definately plan to have the car looked at when I bring it home to make sure that it really is the rod bearings, just in case. Also, I thought about dropping in a 350, but I'm trying to keep this as cheap as possible, for now. I mean, if anyone knows where I can find a nice 350 and the computer, somewhere on the east coast or close to Virginia, then I would definately consider just doing that. I guess I should just wait until I can take a look at the car before I go looking for solutions... haha... Thanks guys.
Old Jul 13, 2003 | 05:00 PM
83 Z28 HO's Avatar
Car: 83 z28
Engine: L69
Transmission: BW t-5
Pull the motor, buy 350, screw the computer use a 4 barrel carb, HEI ignition, and other non computer crap.
Old Jul 13, 2003 | 05:52 PM
RJR99SS's Avatar
or you could just keep the ccc, put in a 350, adjust the carb properly and make the same power as a non-ccc and get better gas milage.
Old Jul 13, 2003 | 08:58 PM
Okay... I really hate to sound like a dunce here... but I'm not very well versed about engines... How would I go about doing this?
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
gord327
Oct 3, 2015 01:25 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
