Entire car torques over when I rev...
Old Jul 12, 2003 | 09:30 PM
sancho's Avatar
Car: '89 Chevrolet Camaro IROC-Z
Transmission: TH-700R4
Axle/Gears: B&W 2.77 Posi
This is in regards to the '89 IROC in the signature...
If I've got the transmission park and I rev the engine up quickly--even to just 2500 RPM--the whole car torques/rotates slightly.
This really doesn't bother me (nor do I often rev my engine for no reason), but I'm just curious if anybody else notices this. I was thinking it might be indicative of a motor-mount or suspension issue, but I'm not sure...
Old Jul 12, 2003 | 09:43 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Put on some subframe connectors.
Old Jul 12, 2003 | 09:57 PM
chooch-88formula's Avatar
some movement it expected... lift your hood and watch your engine... if it moves alot then you have a bad motor mount... if it was a bad tranny mount then the tranny would hit the floor under the center console...
Old Jul 12, 2003 | 10:30 PM
sancho's Avatar
jfreeman74: Please don't say that . I just went through hell getting my Spohn SFCs installed, so if they're not improving rigidity, then I've got some serious problems.
cooch-88formula: The engine does torque a bit in the engine bay, but so does the rest of the car, ever so slightly. The motor mounts are new, standard OEM replacement (i.e. they're not solid or polyurethane).
Old Jul 12, 2003 | 10:34 PM
It sounds like it's normal and you shouldn't worry... but if you REALLY don't like it Then put it a honda motor... They don't have enough torque to break loose the lug nuts on my car....
Old Jul 12, 2003 | 10:38 PM
llvll4l2c91350's Avatar
mine seems to do the same thing. motor mounts and tranny mount are all good. must be the all mighty torque
Old Jul 12, 2003 | 10:40 PM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
My car does this too, but I have to give it a decent rev, about 3,000rpm. Gets there awfully quick in nuetral. ^_^
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
draco
Oct 4, 2015 09:25 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
gwade12
Aug 8, 2015 08:17 AM
