Need specs please
Old Oct 10, 2000 | 07:26 PM
85cam's Avatar
Car: 92 RS
Engine: 396 sbc
Transmission: t5
Need specs please
1967 327 cam, you know the one that supposedly put out 350 hp with the double hump heads from the same year.
I got the cam and I got the heads on a 350 block from 1971 right now in my shop
What are the specs for this cam and these heads??
Thanks in advance
Jason
3" custom FloPro Catback
14X3 K&N open element
15.6 best 1/4 mile before any mods
Old Oct 10, 2000 | 08:34 PM
kjgroen's Avatar
Car: Trans Am
Engine: L69
I have had this cam in two diff 283 engines both making well over 325 horse. It is a great cam with a stick auto is fine if you have a stall and gears. I believe that the speck are 222 duration @.0050 on both sides and 447 lift @.0050 on both sides it has a very strong mid range and you can hear it pulling all the way through the rpm range sounds sweet. The heads depending could be 2.02 or 1.94 and probally have 64 cc combustion chambers if you have the casting#s I could tell you for sure. Kevin
Old Oct 11, 2000 | 12:00 PM
85cam's Avatar
Car: 92 RS
Engine: 396 sbc
Transmission: t5
Thanks!
So I guess with the cam and the heads it is possible that my 350 could make 300 horsies then.
Anybody have any suggestions?
Old Oct 12, 2000 | 07:52 AM
85cam's Avatar
Car: 92 RS
Engine: 396 sbc
Transmission: t5
OK
Kevin here are the casting numbers for the heads
3782461
And the block's casting number is
3970010
Anybody can reply to this not just Kevin!
gord327
Oct 3, 2015 01:25 PM
mfp189
Sep 27, 2015 09:25 AM
wstephan96
Sep 25, 2015 04:28 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
angel2794
Sep 8, 2015 06:22 PM
