Fuel Pump
Old Oct 12, 2000 | 03:28 PM
cobrakiller1989's Avatar
Fuel Pump
I am posting this here because I cant get any replies in the TPI board.
What would be the best gph and psi for a 325-350hp 355 with TPI?
thanks ahead of time
Old Oct 12, 2000 | 11:29 PM
Vader's Avatar
CK,
Most of us are accustomed to rating injectors in pounds of fuel per hour delivery, not gallons. A moderate 355 should require about 24 pounds of fuel per hour at maximum output of 350 HP. That would be in the area of 3.65G/H, or 230cc/M. You should be able to accomplish this with either 22 lb/H injectors at a higher pressure or 24lb/H injectors at standard pressure of about 43 PSIG.
I presume you are asking about RWHP, or an equivalent BHP of around 400.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Oct 12, 2000 | 11:46 PM
thanks alot vader
as usual you have the answer that everyone is looking for
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
