92 RS HEI external coil distrubutor
I did a 305 tbi to 350 carb swap. Will my old distrubutor work? I'd really like to use it cause it's got the MSD GM blaster coil..and I don't have the money for another distributor.
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
it will work for now. problem is you will not have any timing advance. because that is controlled by the computer. it will start and run, just no advance.
Car: 4
Engine: 6
Transmission: 5
No.
It has no provision for advance, other than the computer; which you can't use since it will be hopelessly confused and mad about having no control over fuel delivery.
You will have to have a distributor with mechanical and vacuum advance, otherwise your car will run very lazy, overheat, and get terrible gas mileage. I know that's not what you wanted to hear, but sometimes that's the way the truth is.
You can get kits to hook up an external coil to an early HEI, but by the time you do that, you will spend as much money as buying a whole coil.
There's really no solution other than buying the right kind of distributor.
Engine: 360 HSR
well you can go boneyard hunting for one. here's one from summit
http://store.summitracing.com/partde...art=ACC%2D9107
then a crane external coil conversion kit so you can use the coil you have #730-0590
http://store.summitracing.com/defaul...conversion+kit
RedLeader289
May 28, 2019 01:47 PM
school boy
Oct 22, 2015 11:47 AM
skinny z
Oct 5, 2015 06:23 PM
Damon
Sep 26, 2015 04:29 PM
