can i use on caliper from my 9 bolt disc rear on my new 10 bolt rearend
Old Oct 14, 2000 | 04:48 PM
bad camaro RS's Avatar
i am swapping out my 9 bolt rearend with disc for a 10 bolt disc the ten bolt is missing a caliper can i use one from my 9 bolt on the 10 bolt thanks
1992 camaro RS
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
compucam 2032 with 1.6
482-495 LIFT 214-220 duration full roller rockers
msd6AL
1 5/8 headman headers
2 `1/2 flowmaster exuast
k&n filters gutter air box gutted maf
3 pc under drive pulleys
no emissions no egr etc
custom ED Wright chip
eddelbroc intake base and runners ported plenum
midly ported and polished stock heads
Taylor 8mm wires
B&M mega shifter
gutted maf/airbox
hotchkis lower control arms
2000 tci stall
700R4 with B&M shift kit
Old Oct 14, 2000 | 05:09 PM
freeze92's Avatar
I believe they are the same. There is a tech article in the tech section on upgrading to 1LE brakes. Maybe it can answer your question .
Old Oct 14, 2000 | 06:16 PM
89ROC's Avatar
Yes you can.
When I swapped in a 99' Z28 10-bolt, I used the rotors and calipers from the original 9-bolt rear.
AKA Pony Punisher II on all other boards.
89' Iroc-Z
ZZ3 short block-355 TPI ZZ9 cam
NOS 150 shot.
blah...blah...blah..
95' T-56, 6-speed
99' Z' rearend w/ 4.10's
1997 black Trans AM
A4, bone stock except for the Flowmaster.
hectre13
Dec 11, 2023 08:14 AM
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
