stock fuel lines to Holley mech pump?
Old Jul 21, 2003 | 08:20 PM
Z28cowboy's Avatar
I'm trying to run the fuel lines to my Holley mech. pump. There's a 3/8" line and a 1/4" line running to the old stock pump inlet side. Why two? Is one a fuel return line, if so what do I do with it now? There's only one inlet and one outlet on the new pump.
Old Jul 21, 2003 | 09:06 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
Re: stock fuel lines to Holley mech pump?
The bigger of the two lines is the feed line, the other is indeed a return line. You can just cap it off if your fuel pump is not setup for a return line. Did you switch from fuel injection over to carb?
Old Jul 30, 2003 | 06:04 PM
Z28cowboy's Avatar
No, it was the lg4 w/ the original q-jet. Its now a 355 with many mods that I'm still completing. It's a fresh engine w/ only 15k miles since the upgrade rebuild. The extra inches were nice, but still not enuff power.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
Kaweh
Aug 9, 2015 02:54 PM
