Timing Questions
Old Oct 18, 2000 | 10:50 AM
Formula92's Avatar
Timing Questions
1.) What do you find to be the best base timing set-up?
2.) I heard that 2-4 degrees works well which is 8-10 btdc.
3.) how do you determine total number of degrees timing in your car? Is it burned into the chip?
Thankx for your help!!!!!!!!!
92 Formula,305HO,Factory Oil cooler,Hyper-Tech Chip,Hyper-Tech Coil kit,Dual-Core Split-Fire wire set,Hyper-Tech Airfoil,Accel Fuel pressure guage mounted on fuel rail,Crane Adj Fuel Pressure Reg,March Performance Pulley set,Four Wheel Disc Brakes,WS6 Package,Dual Convertor Exhaust,3.42 Gear/w POSI,5Speed Borg Warner Tranny,Center-Force2 Clutch Set-Up,K&N Filter,ported Plenum.
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
