installing Mechanical Oil Pressure Gauge NEED HELP.
Old Jul 26, 2003 | 03:09 AM
naachoo's Avatar
i have a new Mechanical Oil Pressure Gauge from autometer.
where is my oil pressure sending unit on a 92rs w/305 tbi?
also just need to know how to hook it up to the oil sending unit and have stock guage still work?
thanks
Old Jul 26, 2003 | 03:58 AM
ede's Avatar
ede
oil sender is left of the distributor, or you could tap in to oil passage above oil filter or above and to the right of the timing cover. if you want to use the factory sender location use a 1/8th" tee, nipples, or whatever else you need to plumb the line and factory sender. i'd trash the plastic line and use copper.
Old Jul 26, 2003 | 04:15 PM
Dragons91RS's Avatar
Car: 91 Camaro RS
Engine: 305 LO3
Transmission: 700-R4
Ive been wanting to add a mechanical gauge my self. my car is a 91 with the 305 TBI also.
problem is we do NOT have an oil sender next to the distributer. we have the oil sender/switch combo that is above the oil filter only. so Im at a complete loss as to where to hook a mechanical gauge to. if you figure it out please let me know.
Old Jul 27, 2003 | 01:50 AM
naachoo's Avatar
figured it out! i got mine done today.
look in back of the distributor.. now look real close on the block.u are looking got a screw that has a square head on it. u have to move some wires to see it. u need to take it off and put the fitting into it. its a pain but u will be happy when its done. dont forget to seal it when putting in the new fitting. use some teflon tape.
Old Jul 27, 2003 | 10:02 AM
Car: 91 Camaro RS
Engine: 305 LO3
naachoo thanx for the info
I think I found the right spot. its a small square headed bolt on a little edge of the block just behind the intake and to the right of the distributor(when looking at the engine from the front).
BTW how did you run the tubing for it into the interior of car?
Old Jul 27, 2003 | 07:00 PM
naachoo's Avatar
just drill a hole through. but u need to protect the tubing where it comes though the fire wall or u will get oil into your car after time.
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 21, 2015 09:32 AM
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
ChevyZ71
Aug 13, 2015 07:30 AM
