How to reinstall power steering pump pulley?
Old Jul 26, 2003 | 11:06 PM
Scott C-2
Guest
Posts: n/a
I have a '92 Camaro with the serpentine belt setup. I removed the power steering pump pulley with a pulley removal tool, but the same tool doesn't look like it will help to reinstall the pulley. Is there a specific tool that I can acquire to put the pulley back on properly?
Old Jul 26, 2003 | 11:37 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Threaded rod, nut, big washer
Old Jul 27, 2003 | 12:21 AM
Scott C-2
Guest
Posts: n/a
Threaded into what? The pump snout has a large torx screw type end on it...No threads from what I can see.
Old Jul 27, 2003 | 04:13 AM
ede's Avatar
ede
some pullers also work as an installer, if not use a press
Old Jul 27, 2003 | 08:52 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
There should be threads down in there
Old Jul 27, 2003 | 12:49 PM
Scott C-2
Guest
Posts: n/a
Going to check now...
Thanks for the help, Guys!
Old Jul 27, 2003 | 08:36 PM
25THRSS's Avatar
so did you get it on?
Vintageracer
Jan 10, 2020 05:33 PM
evilstuie
Jan 9, 2020 08:29 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
Street Lethal
Aug 12, 2015 11:33 AM
