Dual snorkel identification
Old Oct 20, 2000 | 03:13 PM
88irocz28's Avatar
Car: 1994 Trans Am
Engine: 5.7L LT1
Transmission: 6-speed
Has anyone seen the latest issue of Hot Rodding? The one with the yellow '91 RS and Chevelle on the cover? Inside the magazine is a picture of the Ram Jet 350 in the Camaro. The dual snorkel on this Camaro has an IAT sensor mounted on it. Can anyone tell me whether that is an aftermarket snorkel or a factory version? I know the IAT sensor came mounted on the underside of the plenum from the factory. Then what could the fitting in the factory snorkel be there for? The reason I'm asking this is because my IROC has the exact same snorkel. The fitting was plugged with a pipe plug, and the IAT sensor was still living in its original location. I relocated the sensor to the snorkel and plugged the hole in the plenum with the pipe plug. The threads and diameter matched perfectly. It was like the IAT sensor was supposed to be there.
'88 IROC 305 TPI
Gutted airboxes
160 degree T-stat
Advanced base TPS voltage
Relocated IAT sensor
Momo steering wheel
Ram-air setup coming soon
Flowmaster muffler
Taylor SpiroPro wires
Accel cap and rotor
Old Oct 20, 2000 | 05:29 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
TPIS makes a kit to move your IAT to the snorkel. V6 MPFI cars have the IAT in the snorkel from the factory.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
91 SrS
Oct 7, 2015 04:32 PM
zman1969
Oct 1, 2015 11:09 AM
