Removing Smog Pump????
Old Oct 21, 2000 | 07:30 PM
CanadianBeast's Avatar
I just took it off but there are two sensors in the plastic black box that all the air hoses run to. I removed the sensors from the box and just put them aside still plugged into the wires. Will leaving them unhooked do anything?? what should I do???
89 camaro 350 TPI
Old Oct 21, 2000 | 09:54 PM
Guest
Guest
Posts: n/a
I dont have the wires hooked up to anything, just taped them out of the way. Been that way for years now.
Old Oct 21, 2000 | 11:46 PM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
I taped mine up too, just don't let them get onto your exhaust manifold like I did and let them melt. It tends to blow fuses, and then you have no gagues, and when you are on a long trip, thats not very good.
Flowmaster,Edelbrock open filliment filter with K&N filter in it
160 stat,
Old Oct 22, 2000 | 12:07 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I just unplugged the wires and put tape on the ends. No problems
Old Oct 22, 2000 | 03:35 AM
My Slow Iroc-Z's Avatar
Those "sensors" as you call them are actually selenoids. They are used to redirect the air to eighter the cat ar to the manifolds. I do believe the computer doesn't "test" if they are there/functioning or not so just pull the plugs and tuck them in a safe place.
Old Oct 22, 2000 | 02:35 PM
thanks for the help I'll just tape them up.
RazorN8
Jan 7, 2022 11:44 AM
italiano67
Dec 11, 2016 09:21 AM
backtothe80s
Sep 5, 2015 12:39 AM
3rdgenparts
Aug 8, 2015 07:09 PM
mustangman65_79
Aug 7, 2015 09:55 PM
