aftermarket steering wheel horn hookup
Old Aug 3, 2003 | 03:03 PM
Midland_GTA's Avatar
Those of you with aftermaket steering wheels, how did you hook up the horn? I am trying to avoid running a bunch of wire up the steering column for my new wheel.
thanks
Old Aug 4, 2003 | 07:23 AM
Vader's Avatar
I used the original wiring and the horn kit designed for the wheel.
Old Aug 4, 2003 | 10:37 AM
EYEROCK89's Avatar
Car: 1989 IROC
Engine: 5.7 / 350 cuid
Yeah, most of those aftermarket wheels should come with a kit to keep the factory horn in sync. If you have a Grant wheel, most auto parts stors carry the install/horn kit for $25. You may actually have to take off all the steering wheel adaption parts and go a little deeper into the column to find the wires...thats what I had to do. Check your Chiltons and find out what color the wires are so you know what to look for.
Old Aug 4, 2003 | 03:33 PM
Joeboy's Avatar
Yeah I used a combination of the supplied kit and what was in the car and kind of reinvented it. It works like a charm.
Old Aug 4, 2003 | 04:49 PM
82camaro's Avatar
Car: 82 camaro SC
On my grant formula gt wheel, one wire from the existing horn spring to the grant horn button--that's it.
Old Aug 4, 2003 | 10:15 PM
86WS6_T/A's Avatar
Car: 2003 Mach 1
On my factory wheel, it was hooked up to the horn button with a female spade connector. Unhooked it from the factory horn button, and hooked it back up to the Grant button.
Works like a charm!
Frozer!!!
Jan 19, 2024 04:55 PM
LittleFranks
Sep 17, 2015 12:22 PM
wild1
Aug 27, 2015 09:01 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
