No Spark
Old Aug 11, 2003 | 11:52 AM
berklified's Avatar
No Spark
i have a 5.7L 350 out of an 87 mounted in an 82 body, it is a carbed engine now
when i got to start the starter works, but there is no spark
i checked what i thought were some of the fusable links, and no luck, i checked contacts from starter up to ignition, nothing
i just checked my coil, with a very low resistance which i believe is correct
i then checked the pick up coil, when checking for continuity from a lead to ground, (distributor body) there is continuity.....
this is bad isn't it?????? is my pick up coil fried?????
need help fast
Old Aug 12, 2003 | 02:58 AM
Vader's Avatar
If the leads were unplugged from the pickup coil, you should not be able to read any resistance to ground. The resistance across the coil should be between 500-1,500 ohms.
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
