Whats a pickup coil?
Old Oct 29, 2000 | 07:17 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Old Oct 29, 2000 | 07:48 PM
Vader's Avatar
Mkos,
The pickup coil is literally that - a coil of wire encapsulated in epoxy resin. The reluctor on the distributor shaft has magnetic poles (one for each cylinder, equally spaced). As we all know, when a magnet passes a wire, it creates a small electrical current. If that wire is coiled tightly and many times, the electrical current is stronger. Therefore, the pickup coil and reluctor magnets produce a small current every time a magnetic pole passes the coil. The pickup coil is wired to the HEI module. This small current is used to trigger the HEI amplifier/switch module to turn the ignition coil primary current off, creating a spark as the coil's magnetic field collapses.
The reluctor and magnet are doing basically the same task as an old Kettering ignition breaker point set would do - to signal the coil when to create a spark so that the correct spark plug gets the spark at the correct time.
Not really rocket science...
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
RedLeader289
May 28, 2019 01:47 PM
school boy
Oct 22, 2015 11:47 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
Eric-86sc
Sep 28, 2015 11:37 AM
