Turbo sizing & tech questions
Old Aug 12, 2003 | 12:11 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
I'm considering a trying a turbo. If I do this, I want to stick to my tried and true, bang-for-the-buck strategy. This means I fab/ mod my own headers, junkyard turbo's, and home tuning.
My first question revolves around selecting a turbo, size wise. I understand size vs lag/peak power compromise. But here is the problem; should I look for a turbo based on displacement&RPM only? Or on HP only (airflow=hp)? For example, my engine is 6.6 liters, and makes ~300 hp @~5000 RPM. With 2 turbos and 5-6 lbs of boost, I would expect it to make well over 350hp @ the same 5000 RPM. So should I look for a 3.3 liter turbo engine for two units, or should I look for two 200 hp engines to get 2 turbos from, regardless of their size?
The second question is about carburation and boost. What are the pro's and con's of blow through vs draw through? If I did a blow through, could I use a Vortech FMU to adjust float bowl presurizing?
Old Aug 12, 2003 | 04:17 PM
badone07's Avatar
Tom,
I don't have the answer for you but if no one else helps, you can look at the link below. I know they also have a newsgroup you can join. It isn't only for Studebakers. I'll be buying their book this week for a project I have going...
http://www.studebakerclubs.com/21stC...bo/Default.htm
John
Old Aug 13, 2003 | 12:04 PM
Engine: LT1, L400
Anyone else?
Thanks Badone. Does anyone else have turbo expirience here??
Old Aug 13, 2003 | 12:32 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
A lot of people do on the Power Adder board might want to search there.
Old Aug 13, 2003 | 01:24 PM
Engine: LT1, L400
Yeah, I didnt' even think of the "power adder" (good name ) board until right after my last post. I'll take it there. Thanks though.
toronto formula
Nov 10, 2015 06:17 AM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
knight72
Aug 10, 2015 09:32 PM
