Car smells like gas
Old Aug 12, 2003 | 10:25 PM
2kickassbirds's Avatar
Car: 1991 firebird formula
Engine: 5.8
Car smells like gas
I have a 89 formula with a 305 tbi with a 5 speed when I get out the car it smells like gas mainly around the back.
Old Aug 12, 2003 | 10:30 PM
25thanniversZ's Avatar
have any amps hooked or still have hooked back there.......if so ya might have hit the tank with the screws....if.........nevermind ya said out of the car...sorry
Old Aug 12, 2003 | 11:27 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Maybe you are running way too rich. Is this after driving the car for awhile or right after starting it up? If it was running for awhile, how hard on it were you while driving?
Old Aug 13, 2003 | 10:58 AM
Jon92TA's Avatar
Car: 92 Trans Am - Sold
I had a bad gas cap, a new one solved it.
Could be a bad pressure relief valve stuck open, or the seal for the filler neck to the tank, or maybe one of the rubber lines up near the tank has a leak. Check it out before it gets worse.
Old Aug 13, 2003 | 01:45 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
I have a bad gas cap as well, and it leaks if I don't tighten it WAY down. I need a new one.
Your filler neck might be cracked, thats a common thing I hear
Old Aug 15, 2003 | 09:47 AM
Engine: 5.8
I've changed the gas cop and I'm always on the gas really hard
bryan623
Mar 22, 2021 06:43 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
mustangman65_79
Sep 1, 2015 03:51 PM
AkDrifted
Aug 17, 2015 07:45 PM
