HELP me somebody
Old Oct 30, 2000 | 10:14 AM
Fastcamaro87's Avatar
HELP me somebody
I have liquid fuel leaking out of the bottom of my carbon canister, im pretty sure its not supposed to do that, anyone have any ideas why its doing this? any help would be greatyl appreciated. thanks
87 IROC-z 305 TPI 5spd Borg warner 9-bolt 3.42 posi 4 wheel disc, no mods yet,just got it.
Old Oct 30, 2000 | 05:07 PM
MY87ROC's Avatar
Car: 87 IROC
Engine: 5.0
there is a replaceable filter in the bottom
but might be to late for that, on full up the tank may have been overfilled which i am told will put fuel in the cannister or maybe the system might not be going into purge which is controled by the ecm via a solinoid on top of the canister i just replaced mine for 85.00 at my local chevy dealer, parts store said its a dealer item, and it came with solinoid also. had no problems since i replaces it.
TPIS airfoil,relocated MAT,AFPR,TB h2o bypass
otherwise stock 5.0TPI
[This message has been edited by MY87ROC (edited October 30, 2000).]
Old Oct 30, 2000 | 05:25 PM
MY87ROC's Avatar
Car: 87 IROC
Engine: 5.0
there is a replaceable filter in the bottom of the canister but may be to late for that. i heard if you over fill the tank gas will get into the canister, or maybe it will not go into purge which is controled by the ecm via a solinoid on top of the canister. i just replaced mine for 85.00 from my local chevy dealer, parts store said that model is a dealer item, it also came with a new solinoid. mine did not leak raw fuel but smelled heavy fumes, no problems since i replaced it
Old Oct 30, 2000 | 05:44 PM
MY87ROC's Avatar
Car: 87 IROC
Engine: 5.0
sorry about double post.... screwed up, not the first or last time (_?_)
Old Oct 30, 2000 | 08:23 PM
Vader's Avatar
Fast,
Look for this under tha canister:
Check all the vacuum lines from the throttle body to the canister. Make sure the purge solenoid is plugged in. Beyond that, you may be in the same boat as ROC.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
