Aluminum 1 row, or C/B 3 row??
Old Oct 30, 2000 | 01:13 PM
Mo's Avatar
Mo
Which should I get? one has a plastic tank and AL core 1 row, the other is brass tank and 3 row C/B core. The Tecnician guy thought the 3 row would cool a shade better, but it is also much heavier.
90 IROC 5.7l (L98)
ram air, K&N's, air foil,Flows
Old Oct 30, 2000 | 07:40 PM
Desert86Roc's Avatar
Depending on what part of the country you live in, neither may do the trick.... I have had them all, and the only thing that really works in the desert is a BeCool, or a Griffin type radiator.... both of which will knock you back over $500 for the model you need.
Your cheapest solution is to go to Autozone, and get their $138 replacement (3core) which comes with a lifetime warranty.
Mike Metzler (Desert86Roc)
Mike@SpeedworldMotorplex.com
[*] Webmaster: SpeedWorldMotorplex.com[*] Click Here For My Racing Page[*]86 IROC 305 TPI (406 build in progress)
ET's @ 1250 ft[*] 14.28 @ 95.461 mph (uncorrected, NOS, no headers)[*] 15.365 @ 86.785 mph (uncorrected, Headers, no NOS)
Old Oct 30, 2000 | 10:27 PM
Mo's Avatar
Mo
I live in the bay area, CA. the copper/brass is $130, the AL is slightly cheaper.
90 IROC 5.7l (L98)
Old Oct 30, 2000 | 11:06 PM
Guest
Guest
Posts: n/a
I'd go with the aluminum, its lighter, and generally speaking they cool better because of the construction. Copper/brass does cool better than aluminum, but the aluminum radiators always have more fins, contact area between fins and rows, more rows, etc etc, which more than makes up for any advantage the copper/brass has. And copper/brass radiators are super heavy by comparison.
Old Oct 30, 2000 | 11:21 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
I've had both in the same car with very different results. In the summer when it's extremely hot here, the super-wide one-core aluminum was able to hold its own, the brass three-core ran a minimum 20 degrees hotter. I won't go with anything other than aluminum.
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
12.57 @ 111 mph.
12.04 @ 114 mph (50-hp nitrous).
http://www.ozemail.com/au/jca69/mods/williesz/willie.html
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
Linson
Oct 24, 2025 02:00 PM
Royal_Z
Sep 30, 2015 08:45 PM
