Can I do this with oil changes?
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I have syn in there now and just did a intake swap and there is antifreeze and stuff in the engine. i am going to drain that and put in regular cheap oil for about 100 miles to clean it out better then switch back over with the syn is this ok to do?
89 FORMULA 350 Edelbrock Cat-Back ,March Pulleys,Super Coil,MSD 6AL ,Edelbrock TES's, AFPR ,Shiftkit, 14.2@98
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
So long as you fix the coolant leak (if that is what caused the coolant in the oil), you should have no problems.
George P. Lara
1994 Z28 LT1 T56
1984 Z28 High Output
Member: SCCA, SCFB, SC3GFB
George P. Lara
1994 Z28 LT1 T56
Car: Formula
Engine: 6.0 LSX
Coolent got int he engine cause i pulled the intake and i didnt get every drop out of there.
Transmission: 4L80E/4L80E
You're doing the right thing. Be sure to change the filter each time as well.
82 Berlinetta, orig V-6 car. Rescued w/86 LG4/TH700R with all harnesses, sensors, ECM, etc. 2.73 open. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, exhaust, paint, etc.).
57 Bel Air, my 1st car. Currently 396 .030 over, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
skinny z
Oct 5, 2015 06:23 PM
