Car running realy hot at all times, seems to cool down at idle.
Old Oct 31, 2000 | 07:06 PM
Crash's Avatar
My car is still running realy hot, 260+, I thought it was the sending unit but when i stop and turn it off, I can hear it boiling and my overflow tank is almost overflowing. So I know it is realy hot and not just a bad sending unit. I think I have some pretty bad vaccum leaks could that do it? My check engine light just came on yesterday (code 44) it says its running lean.
Could bad (low) vaccum make it run lean?
Thanks for any help.
Jason 89Iroc-Z
Old Oct 31, 2000 | 07:22 PM
Guest
Guest
Posts: n/a
Is the fan working?
Airdam intact?
Hows the lower radiator hose (theres supposed to be a spring in it).
Thermostats are cheap, and you know what cheap gets you... try replacing it for the hell of it.
Oh.. and a vacuum leak could cause it to run a little hot, but I'm not sure thats really the root of your problem. Look for disconnected vacuum lines.
[This message has been edited by madmax (edited October 31, 2000).]
specialized
Jun 18, 2022 09:26 AM
bryan623
Mar 22, 2021 06:43 PM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
86Base
Aug 8, 2015 01:34 PM
