Loud ticking noise?
Old Aug 17, 2003 | 12:17 PM
firebird frenzy's Avatar
Loud ticking noise?
allright i have a loud ticking noise coming form the valve cover on the drivers side from all the way in the back. I belive i have some sort of messed up valve or something. I even haven't even opened her up to see whats wrong but i was wondering how determental that loud ticking noise can be to my engine?
Old Aug 17, 2003 | 01:43 PM
FactoryFreak's Avatar
Car: 1988 GTA
Transmission: TH350
My guess would be its just lifter noise. No big deal
Old Aug 17, 2003 | 03:04 PM
thats what i thought but it is excessivly loud like knocking a wrench on the valve cover nad its only doing it in one spot. copuld it be someting else?
Old Aug 17, 2003 | 04:42 PM
Old Aug 17, 2003 | 05:48 PM
TJQIROC's Avatar
Car: '16 Camaro SS, '88 IROC
Engine: 6.2 Gen V
Transmission: 6 spd TR6060
Could be a broken rocker arm, loose rocker stud, or weak spring. The most dangerous is the spring. Swallowed valves don't mix with pistons too good. The least it could be is a bad lifter, noisy but not critical. Find the culprit, tighten according to specs. All that would take is one valve cover gasket. If its a rocker or stud, both can be fixed easily. Try the easy stuff before digging into the hard stuff.
Old Aug 17, 2003 | 07:23 PM
i got the culprit it was a loose rocker nut, thanks guys
Old Aug 19, 2003 | 01:59 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
EDIT: I see you got it.. good
loud91rs
Oct 5, 2015 10:05 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
meeklay812
Oct 1, 2015 03:46 PM
david068513
South East Region
Sep 13, 2015 11:24 AM
