Rotor/Distributor
Rotor/Distributor
so yah i put my car on the lift and checked the fuel pump....its pumping...not as much but still goin.....so i check the position of the rotor and its pointing towards the #3 spark instead of #1....any step by step instructions on how to do this? or should i let the pros take care of it?......thanx again...
....hey at least i didn't dump all that money into a fuel pump
Car: 1986 Firebird
Engine: 2.8 V6
Did you bring #1 (front passenger side on our 2.8 and 3.1 v6's) up to TDC, of the compression stroke, when you checked the rotor position?
All I did was check. I'm kindof sketchy on this subject which is why i'm asking for help. I am clueless when it comes to ignition/spark. Any steps I can take to get you more info just let me know. Lamen's terms help too. ahahahahahah
Car: '16 Camaro SS, '88 IROC
Engine: 6.2 Gen V
Transmission: 6 spd TR6060
Quick test: Disconnect coil wire so the engine will not start. Take out #1 spark plug. put you finger over the spark plug hole and have someone jog the starter. TDC will be when the pressure pushes your finger off of the hole as the timing marks line up. That is TDC. Take off the distributor cap. Rotor should be pointing to #1 plug wire. Follow the firing order (not sure clockwise or counterclockwise).
Car: 1986 Firebird
Engine: 2.8 V6
Well.. you said all you did was check? So you just lifted up the distributor cap and the rotor wasn't pointing at #1?
That's fine, leave it alone.
The engine spins, the rotor spins, etc. The rotor will only point at #1 when the number one cylinder is all the way up in it's bore (top dead center), and the camshaft is set up for the compression (both intake and exhaust valves closed) stroke.
Put the dist cap back on, buy a $40 timing light, and go check the timing.
The engine spins, the rotor spins, etc. The rotor will only point at #1 when the number one cylinder is all the way up in it's bore (top dead center), and the camshaft is set up for the compression (both intake and exhaust valves closed) stroke.Put the dist cap back on, buy a $40 timing light, and go check the timing.
