A/C Compressor Q's
Old Aug 19, 2003 | 04:41 PM
lostangel's Avatar
Car: 86 Z28
Engine: 305TPI stock
Transmission: TH700R stock
A/C Compressor Q's
Does anyone know if someone makes a smaller, lighter A/C compressor that will work with my system? I just can't believe that something better hasn't come along in 16 years.
Old Aug 19, 2003 | 05:26 PM
TJQIROC's Avatar
Car: '16 Camaro SS, '88 IROC
Engine: 6.2 Gen V
Transmission: 6 spd TR6060
I guess you have that big compressor that GM used years ago. Heres something that cost just a "few" bucks
http://www.gmpartsdirect.com/results...umber=12497698
Old Aug 19, 2003 | 07:42 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Do you know if tyhey sell this kit with the ac delete pulley instead of the compressor? I'm wanting to change to the serpentine set-up eventually but don't need the compressor.
Robert
Old Aug 19, 2003 | 10:14 PM
onebinky's Avatar
March Performance makes serpentine conversion kits for about $200, and you could buy a delete pulley for well under $500
Total cost: Probably around $250
Take care,
Matt
Old Aug 20, 2003 | 12:32 PM
lostangel's Avatar
Car: 86 Z28
is the serpentine compressor smaller? mine is made by Harrison and it just seems huge and heavy. Does the serpentine compressor rotate opposite from the v-belt version?
thanks for your help so far.
Old Aug 20, 2003 | 01:33 PM
onebinky's Avatar
They are very similar in weight between, say, a 1986 camaro with VBelt and a 1991 camaro with serpentine. As for the late model cars, I don't know the answer to that one. Both serpentine and vbelt rotate clockwise if you are looking at the motor from the front of the car.
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
anesthes
Sep 30, 2015 07:48 AM
Ironhead38
Sep 7, 2015 02:26 PM
