How much HP is stock L69 fuel pump good for?
Old Nov 3, 2000 | 12:21 PM
Alan84TA's Avatar
I'm finishing my engine and was wondering if I need to upgrade the fuel pump. I'm going to be around 325-350hp...
Old Nov 3, 2000 | 12:24 PM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
You'll be fine, you can even opt for an aftermarket if you like. The mechanical pumps only should put out like 4-8 PSI for an N/A application. Otherwise you could flood your carb with more PSI.
George P. Lara
1994 Z28 LT1 T56
1984 Z28 High Output
Member: SCCA, SCFB, SC3GFB
Old Nov 3, 2000 | 12:29 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
It will probably keep up. If it seems like it isn't, you can pick up a carter street/strip pump for ~$40. Cheap insurance.
...ed
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
justin57
Aug 20, 2015 07:05 PM
Kaweh
Aug 9, 2015 02:54 PM
