Touching an O2 sensor
Old Aug 22, 2003 | 02:34 PM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
What happens when you touch an Oxy sensor, does it usually think you are burning rich or lean after you touch it?
Old Aug 22, 2003 | 08:46 PM
nobody?...maybe i should try the exhaust forum
Old Aug 22, 2003 | 09:07 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
what do you mean touch it?
the sensor has to heat up to a certain temperature (hot) before it sends a usable signal to the ECM.
but if you mean touch the metal on it, I wouldn't worry about it. I really don't think the oil on your skin is going to affect it. Consider its environment.
Old Aug 23, 2003 | 08:47 AM
Vader's Avatar
Most of our cars use a zirconia oxygen sensor. The actual sensing element is covered by a fluted metal cap. Like Token said, touching that shouldn't cause too many problems - at least not as many problems as the urban legend about touching oxygen sensors might cause. The first time you start the engine and the sensor tip reaches about 1,600°F, most of that skin oil should just about be gone.
That's almost as pervasive as the old myth about placing wet cell battteries on concrete. I haven't done any EE math problems for a while, but let's try one:
1.6VDC per cell (on a really good day);
<h1>+</h1>
¼" of polyethylene or rubber casing on the bottom side of the battery, with a breakdown voltage of probably around 16-18,000V;
<h1>=</h1>
Yeah, I'm really worried about the concrete magically sucking all the free electrons out of the acid solution in the battery and into the concrete.
As for temperature, it can't be a whole lot worse than sticking a battery in a metal tray under the hood of a car in -35°F weather.
Then again, concrete DOES have some rather mystical properties. It's almost as unfathomable as a french politician. Concrete does have some magical ingredients in its potion. Maybe it should have been a Maharaji instead of a friggin' rock...
Old Aug 23, 2003 | 12:50 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
hahahahahha
Old Aug 23, 2003 | 06:01 PM
Damon's Avatar
There's an "urban legend" about touching an O2 sensor??? Damn. I missed that one. If I touch 7 sensors for 7 days can I see visions like I'm stoned? Could I grind down O2 sensors and a make a cubic ziconia diamond from the dust? Heh heh.
I've touched a LOT of O2 sensors in very improper ways and they still worked just fine. They're tough little suckers and don't mind being abused by gorilla mechanics very much at all in my expereince. Age and mileage seems to be what kills them (and usually very slowly, not a sudden failure).
Old Aug 23, 2003 | 06:04 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Old Aug 23, 2003 | 07:42 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
Originally posted by Token
LOL
Frozer!!!
Jan 19, 2024 04:55 PM
KED85
Jul 1, 2022 11:59 PM
TRAXION
Oct 12, 2017 03:47 PM
Project: 85 2.8 bird
Mar 5, 2002 03:09 AM
