Who runs 12's with vortecs and no spray? (step inside)
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I am needing to find out which cam and converter to use. I have 3.73's. This is a non computer controlled vehicle. Any suggestions will be appreciated.
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
that run that I made on this sig is shifting at 5000RPM with the car still pulling hard on the stock converter. Im going up to a 235 duration roller cam and a higher stall converter and hoping for mid 12s on the motor and 11s easy on spray
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 280 grind. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter
13.24@104
13.24@104
Iroc8t8
May 4, 2026 08:09 PM
Fast355
Dec 2, 2016 06:33 PM
92camaroJoe
Aug 13, 2015 06:07 AM
