Street legal 400 small block running low 10s?
Old Nov 6, 2000 | 04:31 PM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
ok. i read a mustang article last night. I just wanna see my competition...hehe. this mustang had a ford 4 something bb. running 9.58 or something. naturally aspirated street legal1!!!!! a)what do their engines have on ours to be able to crank out more hp. (yes i know there is more to 1/4 times than engine alone...he had lots of mods in the drive train and suspension.) b)could i run low 10s with a naturally aspirated 400 small block bored stroked with the right setup??? i want to. thanks.
Rick
90 Camaro RS 305 TBI
400 on the way!!
Old Nov 6, 2000 | 04:46 PM
crazeinc's Avatar
you could, but don't bother...you'd need to run a super high compression so you'd need to fill up with race gas everytime and you could make it street legal if you keep it quiet and have it pass emissions, but it wouldn't be street friendly at ALL...if you want to run 10's and still be able to drive it most places just supercharge it or nitrous it, but you need to build the block to be able to handle the extra pressures.
82 Z28
350 carb'd, Edelbrock Performer RPM package (minus heads), Hooker Super Comps, Mufflex 4" offroad y-pipe, 700r4 with B&M shiftkit, '85 IROC 10 bolt rear with Richmond 4.10's & Auburn posi unit, Lakewood 50/50 drag shocks. Shooting for 3000lbs w/ driver.
The car's website
(NO2'd 383/TH350 buildup this winter)
AIM: fillup82Z
ICQ: 77979548
Old Nov 6, 2000 | 04:53 PM
md's Avatar
md
A 406 can be built to 600 hp and run on pump gas and be streatable. It's just an expensive proposition.
Check out AFR's web sight. They have a couple combinations there at 550 & 570 hp. They have mild cam profiles too.
It doesn't really matter though. If you can't get 'er to hook up, then you can't use the power.
Mike
Old Nov 6, 2000 | 04:58 PM
Car: 90 Camaro RS
Engine: 305 TBI
yeah thanks guys. whats the max for pump gas. 11:1?? i plan on having fun with the 400 naturally aspirated for a while then switching into the twin turbo mode. can anyone recommend a cam/head/intake setup for the naturally aspirated mode?? thanks
rick
Rick
400 on the way!!
Old Nov 6, 2000 | 06:49 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
look here- http://web.camaross.com/bb/Forum13/HTML/002968.html
and here
http://web.camaross.com/bb/Forum13/HTML/002514.html
10s is not a problem. Low tens requires that the weight be in the 3200 lb range (approx 1 hp for every 5.5 lbs should do it) and quite a bit of suspension work. Plus you are talking about 134 on the top end. Your going to have to twist it pretty hard and have about a 4.10 gear.
[This message has been edited by jcb999 (edited November 06, 2000).]
jhawkeye
May 25, 2022 06:33 PM
9192camaro
16
Feb 3, 2019 12:21 AM
theshackle
Mar 5, 2017 06:37 PM
Fast355
Dec 2, 2016 06:33 PM
camaro71633
Sep 1, 2015 10:24 AM
