door manual lock thing
Old Aug 28, 2003 | 07:16 PM
83BlackBeauty's Avatar
Car: 83 Trans Am
Engine: 5.7 (350) TPI
Transmission: soon to be 700r4
Axle/Gears: 9-bolt rear. gears? hell if i know
on the side of the actual door, there is some mechanism that is engaged and it won't let me shut the door
Old Aug 29, 2003 | 05:03 AM
ede's Avatar
ede
try moving the latch with a screw driver, open the door and it'd be the part that engages the striker. you might want to make sure the striker hasn't moved too. if it's the lock it's self you can remove the door panel to gain access to it and move it manually, or repair it if needed.
Old Aug 29, 2003 | 06:07 AM
EYEROCK89's Avatar
Car: 1989 IROC
Engine: 5.7 / 350 cuid
Yeah, Ede has it right. It should be a pretty easy fix. My S-10 used to do that alot. It helps if you lift up on the door handle while you try to pull the mehanism back.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
BlackTopKing
Aug 19, 2015 12:13 PM
Bob88GTA
Aug 18, 2015 03:31 PM
