vortec heads/tpi
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
vortec heads/tpi
how well do the vortecs really work good? I can get a set for 100.00 are they worth it? and I want to use the lt1 intake later but, I thought the tpi lower would work if you added aluminum to the top?
Car: Faster
Engine: Than
Transmission: You!
Vortec heads are awesome! But, you will have to get a correct intake for them. Adding material to cover up gaps on a regular intake will work, but the ports will still be off. If you just have to stay LT-1 style, then you can convert an LT-4 intake which will work with vortec heads.
Engine: ls1, LB9
I was just looking at the lt1 manifold convertion prices holy cow! they are very $$$$$$ for used converted stuff. maybe I will pass on the heads I mean why spend that much cash when you can buy a better intake for just a little more.
Chas91Z28
Oct 22, 2015 10:12 AM
monte87cortez
Sep 26, 2015 08:10 PM
